If you have the security alarm set with your key chain and unlock the door manualy with the key while the alarm is still on it does not set off the car alarm but dis-ables the ignition system. The car will crank but not start. Re-lock the doors and set the alrm then disable the locks with the key chain and the car will start.
SPONSORED LINKS
Wednesday, June 10th, 2009 AT 4:36 PM
