Minor accident, literally no visible damage, but afterwards the ABS, Airbag, and Service engine soon came on and would not go out. Upon moving vehicle to side of road, we though all was well, then it would not go back into any gear. I did manually shift out of park removing the boot and rasing the white gear. When I got home, I played around with it. I turned the headlamps from the auto position to on and the trasnmission would then change gears, put lights back to Auto and the gears will not shift. Is this a BCM problem or just a resistor or snesor for DRL?
OH looks like the A/C stopped working too.
Jan 2, 2010 at 2:49 PM
