Engine runs rough at start
125,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
COVEY KAY DEBORAH
when i first crank up, the idle is fine and then when i put it in gear, it is like it's flooding or not getting the right air fuel mixture. It wants to miss sometimes misfire like its choking itself down, then as i keep going it smoothes out. Then after running for a while, it is difficult to start but after letting it sit for 15-20 minutes starts up. The plugs and wires are new.
May 4, 2022 at 8:55 AM
We need to check a couple things first to find out what this could be.
First, we need to check the fuel pressure when this is running rough and then when it is hard to start.
Once we know what the fuel pressure is when this is happening the next thing is to find out what the o2 sensors are doing.
Basically, we need to find out if the sensors are showing rich or lean.
If they are showing, there are no issues then we may have an o2 sensor issue.
I am attaching a chart below that will help with figuring this out and so let's start with this and go from there.
Thanks
May 5, 2022 at 9:53 AM
COVEY KAY DEBORAH
it has new O2 sensor put on in last 7 months will have fuel pressure checked car seems to be starting better after running now but is sluggish at first but smooths out also have added seafoam to fuel and cleaned throttle body with cleaner while engine running. The car runs around 200 degrees down the road and also has a new coolant temperature sensor and thermostat along with new water pump and hoses. cooling fans come on as they are supposed to around 226 have checked for vacuum leaks but have not found any as was as bad electrical wires fuel pressure valve seems to be good no leaking.
May 6, 2022 at 1:44 AM
Has this vehicle been sitting for any amount of time or is it a daily driver?
If it has been sitting, then I would completely drain the fuel tank and put fresh clean fuel in it and think about changing the filter as well.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
With it being a Corvette, they normally sit so I suspect you have a fuel quality issue.
May 6, 2022 at 2:00 AM
COVEY KAY DEBORAH
Has a new fuel filter but have only driven it about 2,000 miles in last 2 years.
May 6, 2022 at 3:03 AM
Okay. When was the last time you put fuel in it? If it was more than 60 days, then I would drain the tank completely and fill it with fresh fuel.
Don't try and use additives at this point as they are just chasing the problem. You need to start fresh and then if you want to add a bottle of Seafoam or fuel stabilizer then that is fine.
The reason is, as fuel sits, it absorbs moisture from the air. Some moisture is fine but once you tip past that point, you will not correct it unless you drain it and add all new fuel.
Plus, if you are only going to drive 1000 miles per year, I would only put enough fuel in it that will get you through the drive that you are making. Meaning if you are going on a 20-mile drive. Just put a few gallons in it.
Also, don't store the fuel in the tank. Meaning get a 5-gallon fuel container and fill that and treat the entire 5 gallons with stabilizer and then when you are going to go on a trip with the car, put that fuel in it at that point.
Those fuel containers seal the fuel better and prevent moisture from getting in better than your fuel tank does.
Let me know what happens with fresh fuel and we can go from there.
Thanks
May 6, 2022 at 3:12 AM
COVEY KAY DEBORAH
What is the best way to drain the tank? Because i have been adding new fuel recently and trying to drive it every day or so, I have probably run a tank full of new fuel in the past month.
May 6, 2022 at 4:18 AM
Okay. There are a number of ways to do this. On this vehicle, I would just siphon it from the filler neck. You can buy all sorts of different pumps that will do this easily rather than sucking on a hose.
Another way is to disconnect the fuel line and run a rubber line into a tank and then turn the ignition on and let the pump drain the tank. You will need to cycle the key a bunch of times if the tank is full.
So, I would just get a pump and siphon it.
May 6, 2022 at 9:32 AM
