1990 Chevy Corvette run bad when warm
1990 CHEVROLET CORVETTE
87,200 MILES • V8 • 2WD • AUTOMATIC
KRUZN
reading other customer problems same as other vett
on web site
Jul 24, 2009 at 5:02 PM
BUDDYCRAIGG
  • CAR REPAIR CONTRIBUTOR
  • 2,262 POSTS
I don't know what other problems you have read, so could you describe what's going on?
and if you have tried to do any testing?
Jul 24, 2009 at 6:34 PM
KRUZN
90 VETT CAR RUNS VERY BAD WHEN WARNED UP RUNS LIKE EXH STOP UP WILL IDLE BUT WONT TAKE FUEL. READED OTHER CUSTOMERS PROBLEM ON WEB SITE SOUNDS ALOT LIKE MINE TESTED RESISTANCE ON INJECTORS GOT READINGS FROM A LOW OF 8 OHMS TO A HIGH OF 17.8 OHMS I THINK YOUR TECH RECCOMMENDED TO REPLACE INJECTORS ON OTHER VETT IAM NOT SURE BUT THINK RESISTANCE SHOULD BE ABOUT 1-2 OHMS CAR JUST HAD MAJOR TUNE UP HAS GOOD FUEL PRESSURE IF U HAVE A MINUTE AND CAN LOOK AT WEB SITE COMMENTS ON OTHER 90 VETT THERE ARE A HOLE LOT OF SMILARITIES IN THE TOO CARS THANKS FOR INFORMATION
Jul 27, 2009 at 1:59 PM
BUDDYCRAIGG
  • 2,262 POSTS
I am not going to read about the problems for some other car. I would have no way of knowing if each and every symptom was the same as yours. or if you have symptoms that they did not.
So after the engine is at normal operation temperature, you can not get it to run above idle?
Jul 27, 2009 at 2:09 PM
KRUZN
YES NO POWER OFF IDLE THINK MAYBE INJECTORS HAVE PROBLEM
Jul 27, 2009 at 6:44 PM
BUDDYCRAIGG
  • 2,262 POSTS
will it rev in park or neutral?
Jul 27, 2009 at 7:12 PM
KRUZN
TO A POINT, RUNS LIKE CAT IS PLUGED UP, BUT ITS NOT EVEN WITH EXH OFF STILL WONT REV UP
Jul 28, 2009 at 10:08 AM
BUDDYCRAIGG
  • 2,262 POSTS
do a test to see if it's because it's starving for fuel.
while working the throttle, spray starting fluid in it in an attempt to get the RPM up.
Jul 28, 2009 at 7:31 PM
