I replaced the water pump and thermostat. However, now it's still running hotter than it should. At some point in time there was stop leak out in it by the previous owner. I have no clue why. Truck still runs pretty decent. However, this morning on my way to work I didn't have heat for around twenty minutes and when the heat finally did kick in the gauge didn't drop at all. Very low heat too usually that truck will roast you out of the cab.
Apr 24, 2019 at 1:51 AM
