2001 Ford Ranger Engine running hot
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
ASHLEYKENNARD83
Hi, my truck has been running hot. I have bought a temprature sensor and want to put it on, but cant find where it goes. Also I have changed the thermostat, checked all the hoses and connections for leaks and found none. If you have any suggestions please let me know. Thanks
Sep 27, 2009 at 2:43 AM
RENAUDTN
  • 636 POSTS
*Flush radiator
*Check serpentine belt and tensioner
*Make sure your cooling fan kicks on when needed.
*Sometimes, the bottom hose can collapse inside (but still look good outside) resulting in reduced flow.
*leaky headgasket: test for exhaust gas in coolant
Sep 28, 2009 at 5:14 AM
