Rough idle and loss of power
180,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
BLAINE KEREKU
I just overhauled the engine. Replace new piston rings and oil seals. I started the engine, and it gave me all these problems.
Oct 16, 2021 at 2:43 PM
We don't have a manual on this engine so I can't provide specifics, but we need to find out if these issues in these guides are there because they will cause these issues.
First is a vacuum leak. We need to use this guide to inspect for a vacuum leak to find out if we have a line off or even an intake manifold leak:
Next, we need to find out if you have good compression as you will have low power and rough running if the compression is not correct.
Lastly if both of these check out then we need to run through this guide that talks about this issue in more general terms:
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Let's start with all this info and we can go from there. Thanks
Oct 17, 2021 at 2:55 AM
