rotors and brake pads
116,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
I purchased Raybestos rotors. Can I use carbon fiber brake pads with non-carbon fiber rotors?
Mar 23, 2021 at 2:32 AM
I-SMOGEM
  • 118 POSTS
Hi PCULQUI,
Stock-type pads will work fine but it really depends on how you drive the car. Some makers of drilled/slotted rotors will specify what type of pads can (and cannot) be used with them. Ceramic pads can be a good choice if you don't want the brake pad dust. Look at the Raybestos ceramic pads. Very little dust, quiet, and ceramics have excellent bite when cold. Once they get a bit of heat in them, they work very well for street use or "spirited" driving.
There is a misconception though that carbon ceramics will allow the car to stop faster. That is not true. They only have a longer life span than the steel carbon brakes.
Hope this helps. Glenn
Mar 23, 2021 at 3:38 AM
PCULQUI
  • 354 POSTS
I am purchasing Akebono brake pads. Will these be good with the Raybestos rotors for no dust and instant braking?
Mar 23, 2021 at 8:25 AM
I-SMOGEM
  • 118 POSTS
I see the Akebono pads are carried by NAPA and Pep Boys in my area, and likely carried by others. Manufacturers of rotors and pads may (and usually do) have trade secrets on their composition, materials, design, but that doesn't mean mixing manufacture's parts is detrimental. That in itself, would not make much business sense, and many have a "Satisfaction Guarantee".
The "instant breaking" would entirely be judgmental by you. Your driving habits, road conditions, tire conditions, and many other things effect them. Basically, what your neighbor says is great, you might think they stink. As stated above, if you are not satisfied return/exchange them. And, it's the ceramic pads that have reduced dust compared to other types.
Check this site for a good comparison of brake pad materials:
https://www.bridgestonetire.com/tread-and-trend/drivers-ed/ceramic-vs-metallic-brake-pads#
Glenn
Mar 23, 2021 at 4:21 PM
