2004 Toyota Sienna ABS
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
LALTAZAN
how do you fix abs problems
Apr 2, 2009 at 1:04 PM
WILLIAM OLIVER
  • 25 POSTS
first you will need to know what codes the vehicle has stored that way you will have idea from where to start . can be the abs controller/wheel sensor or wires or abs actuator but check for codes fist ..There are simply too many parts involved to just guess
See the video below on ABS, it may help you out
https://youtu.be/Pb6nXV-iamI
Apr 3, 2009 at 1:33 PM
