shaking at sixty mph
2008 TOYOTA SIENNA
160,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JOEL SANDOVAL MONDACA
  • 5 POSTS
at about sixty mph I start noticing a slight shaking then at about seventy to seventy five mph the shaking is very bad sometimes. sometimes will not even notice any shaking at all. What I notice is the front right wheel and the left rear wheel get slightly tight. then i need to bleed the brakes front right and left rear and it pours some brake fluid out. I have no idea if this is related with the van shaking. thanks for your replies.
Mar 11, 2017 at 4:46 PM
HMAC300
  • 48,601 POSTS
with the brakes off check to see if fluid squirts out or barely comes out. if it squirts then it may be a bad brake hose or caliper is freezing up . then get tires checked for balance. could be an axle shaft, but it may be more of a tire problem.
Mar 12, 2017 at 9:07 AM
  • 5 POSTS
Tried diff tires and different rims balanced alignment.
Mar 12, 2017 at 9:18 AM
  • 5 POSTS
When the wheels are tight the brake fluid would squirt out.
otherwise will not bleed out.
Mar 12, 2017 at 9:21 AM
  • 5 POSTS
Caliper pins cleaned and lubed with silicon lubricant.
Mar 12, 2017 at 9:25 AM
HMAC300
  • 48,601 POSTS
With the brakes off check to see if fluid squirts out or barely comes out. If it squirts then it may be a bad brake hose or caliper is freezing up.
Mar 12, 2017 at 9:45 AM
  • 5 POSTS
After going for a ten minute ride the right front side and rear left side brakes get locked.
if i loosen the bleeder, fluid would squirt out.
i have gone through a couple of brake pads and it is just the front and rear left that are worn out to the metal.
Mar 12, 2017 at 12:19 PM
HMAC300
  • 48,601 POSTS
have a mechanic check for a frozen caliper or it is hanging up and not moving in brackets. they should slide in brackets. rust can cause this also.
Mar 12, 2017 at 12:27 PM
