rotor assembly hub to rotor
134,000 MILES • 2.6L • 4 CYL • 2WD • MANUAL
SHADETREEDUDE
do I need to use torque specs when tightening the rotor assembly to the rotor? thank you.
Aug 31, 2017 at 7:35 AM
STEVE W.
  • 15,394 POSTS
Rotor to hub bolts are torqued to 47 ft lb. Torque them in a star pattern so they are even. Clean off all the rust/dirt from the hub as well. I will apply a thin wipe of never seize or spray with fluid film before assembly. Makes them come apart better the next time.
Lug nuts - 83 ft lb.
This is a good video on the process.
https://www.youtube.com/watch?v=p6smTU_SnPg
Aug 31, 2017 at 8:02 AM
