Followed your instructions and replaced the TCU. Seems better,but still clunks going into reverse. Also, the speedometer doesn't work.
Jun 15, 2023 at 8:02 AM
✓Experienced Mechanic
This sounds more like an engine/transmission mount. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. Do you have any trouble codes? I would lift the hood and watch from the side of the car while you have a helper start the car and put it in reverse and then into drive and watch for excessive movement which is telling you the mounts need to be replaced.
