Replacement part for turn signal lever?
180,000 MILES • 4.9L • V8 • 2WD • AUTOMATIC
SHMELIODAS
The multifunction lever that controls turn signals and stuff broke and I need a new one, but am unsure what years of other Deville's I could pull one from, that will work. Found some earlier the earlier 91-93 and also the 96, but none for mine.
May 13, 2023 at 6:15 AM
STEVE W.
  • 15,423 POSTS
If you mean the lever that has the cruise switches it is simple to replace, the hard part is fishing the wiring down through the column tunnel. For the replacement you remove the lower steering wheel cover and remove the tape holding the wires, then go under the dash and unplug it, then gentle pull the wires up so the guide wire can be used to pull the new harness back down. As for which other one's interchange, 94-95 should fit as long as they have the full number of switches. They used them in most of the luxury GMs like the caprice, other Cadillac's, Buicks, and Oldsmobile's.
May 14, 2023 at 12:05 PM
SHMELIODAS
Thank you. I appreciate the help. I should be able to find what I need a bit easier now.
May 14, 2023 at 12:14 PM
STEVE W.
  • 15,423 POSTS
Good luck, it's getting harder to find parts for the pre 2000 cars these days.
May 14, 2023 at 2:25 PM
