Replaced alternator that shorted out car cut off nospark when cranking errior codes P1684 P1388 P1193
EDWARD42
  • 2001 CHRYSLER TOWN AND COUNTRY
  • 3.8L
  • 6 CYL
  • 134,000 MILES
Check auto shut down relay withanother relay still no spark
Saturday, January 17th, 2015 AT 11:19 AM
HMAC300
  • 48,601 POSTS
P1684 is nothing to worry about it just means that the pcm has been cleared. 1193 is inlet air temp sensor if it has 4.2 volts going in on dark blue/lt green wire and not over5.2 volts then it's ok.1388 see pic and check fuse 16 however this may be the integrated power module that is bad.
Saturday, January 17th, 2015 AT 1:26 PM
