Replace engine now will not start
164,000 MILES • V6 • 2WD • AUTOMATIC
LA LA
  • 6 POSTS
We had the engine replaced drove it home no problems. Took it for new tires turned the car off now it will not start. Any suggestions?
Dec 23, 2017 at 6:47 AM
STEVE W.
  • 15,411 POSTS
What does it do when you turn the key? Nothing? Clicks but does not crank over? Cranks over but does not start? What do the headlights do when you try to start it? Do they come on bright and dim while you turn the key? Do not come on at all?
Dec 24, 2017 at 9:37 PM
LA LA
  • 6 POSTS
It cranks over but will not start. Headlights and interior lights stay on.
Dec 24, 2017 at 10:05 PM
STEVE W.
  • 15,411 POSTS
Okay, then you need to do some testing to determine if you lost spark or fuel pressure. A quick way to check is to spray a bit of starting fluid into the engine and see if it tries to run. If it tries to run then it is likely a fuel related problem, either the pump failed or it is not getting power.
I would also contact whoever did the engine replacement, this should be something they would take care of, but being the holiday season that might take a while.
Dec 25, 2017 at 3:02 AM
LA LA
  • 6 POSTS
It was a bad distributor cap. Replaced that now the fan won't come On, smh
Jan 7, 2018 at 1:25 AM
STEVE W.
  • 15,411 POSTS
Well that's good and bad...
You mean the cooling fan correct? That won't turn on with engine heat until it gets up to 230 degrees F. To test that you need to be able to watch the actual temperatures the computer sees. That requires a scan tool to monitor the temperature from the sensor.
Jan 7, 2018 at 5:49 AM
LA LA
  • 6 POSTS
Yes, the radiator fan. Thanks for the info
Jan 7, 2018 at 6:03 AM
STEVE W.
  • 15,411 POSTS
If you can verify the coolant temperature and then see that the fan isn't working there are more tests that can be done, but testing without knowing if the temperature is even hot enough is sort of a waste of time.
Jan 7, 2018 at 6:35 AM
LA LA
  • 6 POSTS
Ok thanks gonna start there
Jan 7, 2018 at 7:39 AM
