Renault Clio Engine Fault
RENAULT
CALEDONIA_112
Renault Clio 1997 1.4 8v single point injection. 30,000 miles. hey guys when the car is pulling away or accelerating from low revs it judders as about to stall. even with the throttle fully depressed i initially thought it was the ignition system and since new ht leads rotor arm cap and plugs i figured coil. after i changed this it did appear better for bout a week. now its doing it again and im thinking fuel. i have had two occasions when the car struggled to start. im thinking sum sort of sensor any ideas?
Feb 21, 2006 at 1:23 PM
PEPPERMRJ
  • 1,158 POSTS
Check for proper fuel pump pressure, a dirty fuel filter, and run some fuel injector cleaner thru a tank or two.
Post back. :)
Feb 23, 2006 at 2:17 PM
