1999 Renault Clio No Spark
RENAULT
MICHAELAPALAZZO
HELP!!!
I have a clio 1.4 1999 everything works but there is no power going to the coil so there is no spark.... please someone help me
Oct 2, 2007 at 5:48 AM
DAVE H
  • 13,383 POSTS
is the little red light on the dashboard flashing real fast when you put the ignition in the on position .. if it is, then your immoboliser has activated .. and needs to be reset by renault dealer or an independant with the correct software
Nov 8, 2008 at 6:24 AM
Suggested Repair
With the ignition on, check whether the small red dashboard light flashes very rapidly. If it does, the immobiliser has activated and must be reset by a Renault dealer or an independent shop with the correct software.
Conversation Summary
The owner of a 1999 Renault Clio 1.4 reports that everything else works but there is no power to the coil and therefore no spark. The expert says a rapidly flashing red dashboard light with the ignition on means the immobiliser has activated and needs a software reset by a Renault dealer or a properly equipped independent.
