2004 Renault Megane Renault Megane II wont start
65,000 MILES • 4 CYL • FWD • MANUAL
TOXICAXEL
The car wont start and the radiator fans start in full throttle and remain on even after I close the car for about 2 minutes.
On the board it says that there is a Electronic Fault.
I started the test mode and it displays the following error:
"Panne capteur
Temp. Eau
Debimetre"
I guess that Ihave a problem with the Coolant Temperature Sensor but I don't know where it is located to try and clean it or to know what part to buy and change.
Please help me.
What do you sugest?
Feb 1, 2009 at 5:11 PM
DAVE H
  • 13,383 POSTS
you need to have the vehicles PCM (computer) read for fault codes .. you may have a fault on the actual computer itself ..it really needs to be plugged into a diagnostic computer to verify where the actual fault lies ?
Feb 3, 2009 at 10:51 AM
TOXICAXEL
i conected to the calculator and it says that the UCH is fried.
Where is situated this UCH and do I have other solutions then to buy one that costs only 250euro without instalations!
Feb 3, 2009 at 11:50 PM
DAVE H
  • 13,383 POSTS
could you supply the actual fault code for me ie. PO300 or PO451 .. etc. .. I do not know what a UCH is .. but can translate from the fault code !!
Feb 4, 2009 at 1:17 AM
