Reduced power, TPS
2015 CADILLAC ESCALADE
102,000 MILES • V8 • 2WD • AUTOMATIC
JASON HARRIS SR.
Loss of power, message reduced power. OBD, TPS.
Sep 1, 2018 at 6:53 PM
Good morning.
There is a code attached to this issue. Do you have the code number? If you do not, you can have it read at a parts store for free. Once I know the code, I can help narrow the area of failure for you.
Common failures are:
1. TPS sensor.
2. TPS sensor connector damage.
3. Fuel pedal sensor and wiring.
These will need to be checked for any issues prior to replacement.
Sep 1, 2018 at 9:49 PM
