2002 Cadillac Escalade Reduce engine power
MERIIO13
  • 2002 CADILLAC ESCALADE
  • V8
  • AWD
  • 14,500 MILES
I have a 02 escalde the problem I'm having is when I turn it on computer message says reduce engine power also it says stubility systum when I try to push the gas pedle the rpm does not go up
Tuesday, November 3rd, 2009 AT 6:39 PM
FACTORYJACK
  • 4,159 POSTS
That is usually in response to a fault with the drive-by-wire, or throttle actuator control system. What you are experiencing is limp-home mode. There is no sure-shot cause for this. It will have code(s) in the system, possible that you have a faulty throttle unit, or accelerator pedal position sensor fault. Both of these items house two sensors that cross check each other.
Wednesday, November 4th, 2009 AT 10:23 PM
