Reduced engine power?
110,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SPARKHED
As long as I keep rpm's at 800 or so and above I have no problem. If I come to a stop and don’t keep the rpm's up I may get a reduced engine power message. I turn it off then back on and I may or may not have a check engine light. AutoZone scanned it and came up with these codes. P0172, P0175, p0220, p1516, and p2135. I’m at 110,000 miles and I’m guessing original spark plugs and who knows what else original. I was thinking a tune up would be the ticket( plugs, filters, oil) till they scanned it. It idles around 600 rpm when it wants to run. I suppose it’s low enough that a loose connection might show up cause of vibration. Any help is appreciated!
Sep 15, 2019 at 7:54 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I would try to clean the throttle bore it helps fix these problems, then clear codes
Lets look at what each code is indicating and then see if there is a common denominator between all.
DTC P0171
- Fuel Trim System Lean Bank 1
DTC P0175
- Fuel Trim System Rich Bank 2
DTC P0220 The TP sensor 2 voltage is less than 0.25 volt or more than 4.59 volts for more than 1 second.
DTC P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P2135 - Throttle Position (TP) Sensor 1-2 Correlation
As you can see, they are all fuel related. There is a good chance the throttle body itself needs replaced. However, before jumping to that conclusion, I need you to check for a couple things. Since one bank is lean and the other is rich, check to see if there are any exhaust leaks before the catalytic converters. It doesn't have to be loud. It can sound like a ticking, especially when cold.
Next, follow this link and check for other vacuum leaks.
https://.2carpros.com/articles/how-to-use-an-engine-vacuum-gauge
Next, if I had to guess, I would say there is a short to power between throttle position sensor one and two. I need you to check the wiring at the throttle body. Make sure it is not damaged, the connections are clean, tight, and internally not damaged, and make sure there are no cuts in the wiring insulation.
If I recall, this throttle body isn't serviceable. If you are comfortable with testing the electrical end of the system, let me know. I have flow charts (which are quite extensive) I will send. I am not going to overwhelm you with them if you don't want them
I attached a picture of the throttle body. That is where i need the wiring checked. Also, I circled an o-ring that can cause a leak, so make sure to check around there for issues.
Let me know what you find.
Sep 15, 2019 at 9:22 AM
JIS001
  • 3,412 POSTS
Hi and welcome to 2CarPros. Just wanted to jump in and help out. If you have a K&N filter chances are the mass air flown sensor is contaminated and needs replacing. But for the the throttle codes do this. Remove the throttle body without disconnecting the connector. Clean out the throttle body front and back. This should take care of the idle issue. Here is a bulletin on P1516. 99% of the time in my experience cleaning the throttle takes care of this fault.
Collision
 92
2007 Chevy Truck Silverado 1500 4WD
V8-5.3L
SES Light, Idle Surge, and/or Reduced Engine Power Mode with DTCs P0068, P0121, P0506, P0507, P1516, P2101, P2119, and/or P2176 - Clean Throttle Body and Perform Idle Learn Reset
Vehicle Powertrain Management Technical Service Bulletins SES Light, Idle Surge, and/or Reduced Engine Power Mode with DTCs P0068, P0121, P0506, P0507, P1516, P2101, P2119, and/or P2176 - Clean Throttle Body and Perform Idle Learn Reset
SES LIGHT, IDLE SURGE, AND/OR REDUCED ENGINE POWER MODE WITH DTCS P0068, P0121, P0506, P0507, P1516, P2101, P2119, AND/OR P2176 - CLEAN THROTTLE BODY AND PERFORM IDLE LEARN RESET
#PIP4578B: SES Light Idle Surge And/Or Reduced Engine Power Mode With DTCs P0068 P0121 P0506 P0507 P1516 P2101 P2119 And/Or P2176 - Clean Throttle Body And Perform Idle Learn Reset - (Dec 18, 2017)
Subject: SES Light, Idle Surge, and/or Reduced Engine Power Mode with DTCs P0068, P0121, P0506, P0507, P1516, P2101, P2119, and/or P2176 - Clean Throttle Body and Perform Idle Learn ResetModels: 2007 Buick Rainier2007–2018 Cadillac CTS-V,2007–2018 Cadillac Escalade2006–2014 Chevrolet Avalanche2010–2018 Chevrolet Camaro2006–2018 Chevrolet Corvette2008–2009 Chevrolet Colorado2006–2017 Chevrolet Express2006–2009 Chevrolet Impala2006–2009 Chevrolet Monte Carlo2006–2018 Chevrolet Silverado2006–2018 Chevrolet Suburban2006–2018 Chevrolet Tahoe2006–2009 Chevrolet Trail Blazer2008–2009 GMC Canyon2006–2009 GMC Envoy2006–2017 GMC Savana2006–2018 GMC Sierra2006–2018 GMC Yukon2007–2008 Hummer H22008–2009 Hummer H32007–2008 Pontiac Grand Prix2008–2009 Pontiac G82006–2009 Saab 97xWith a V8 Engine
This PI was superseded to update model years. Please discard PIP4578A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:As carbon builds up in the throttle body of a high mileage vehicle, the ECM/PCM learns to compensate by increasing the throttle plate angle.
If enough carbon builds up, an idle surge, deceleration surge, tip-in hesitation, reduced engine power mode, and/or DTCs P0068, P0121, P1516, P2101, P2119, and/or P2176 may be experienced on high mileage vehicles.
If the throttle body is cleaned without performing an "idle learn reset/reset idle learn" with the Tech 2, the ECM/PCM may continue to compensate for previous carbon build up, causing it to return with a similar concern as well as DTCs P0121, P0506, and/or P0507.
In a similar fashion, if the ECM/PCM of a high mileage vehicle is replaced and/or reprogrammed without performing the Throttle/Idle Learn outlined in SI, the ECM/PCM may no longer compensate for existing carbon build up in the throttle body, causing it to return with a similar concern as well as DTCs P0121, P0506, and/or P0507.
If SI diagnosis does not isolate the cause of this concern, inspect the throttle body bore and plate for obvious carbon build up.
If carbon is present, follow the Throttle Body Cleaning Procedure in SI to clean the throttle body.
After ensuring that the throttle body bore and plate are clean, perform an "idle learn reset/reset idle learn" with the Tech 2 and re-evaluate the concern.
Notice: Depending on the vehicle you are working on, the "idle learn reset/reset idle learn" is normally found on the Tech 2 ECM menu for Module Set Up or Special Functions/TAC System.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Now the reason I say do not unplug the throttle is if you unplug it and clean it the idle will be really high and the only way to bring it back down is to do a software update. For the running rich most likely the mass air flow is faulty and I recommend you replace it with an A/C Delco part. But clean the throttle body first. Reset the codes and let us know after a 100 miles if the fuel trim faults return.
Sep 15, 2019 at 5:03 PM
SPARKHED
Thanks for the replies! This truck is an extra and sits a lot. I’m going to try to spend some time on it tomorrow. Jis001 I don’t have a K&N filter, should I still try to clean the throttle body and do I need to reset the code afterwards? It looks like something needs reset in your reply, how would I go about doing that? I’m pretty confident in my ability to do the work I just have limited knowledge. Thanks for you help!
Sep 27, 2019 at 1:51 PM
JIS001
  • 3,412 POSTS
Hello and welcome back. You should still inspect the throttle bore. If you do not drive much you may have carbon build up. Inspect it and clean it if is dirty. To reset the trim I would recommend you disconnect both battery cables and touch the leads together to do a "reboot" of the computer after you clean the throttle.
Sep 27, 2019 at 2:41 PM
2CP-ARCHIVES
  • 4,540 POSTS
This is a 2500HD truck with the 6.0 L engine. The problem is while driving it will sometimes get the reduced engine power. You can stop, turn the key off for just a few seconds and restart it and it will run fine, sometimes for days or weeks at a time and sometimes only for a few miles. Also when this happens and you restart the truck you will see that the engine hours has cleared to 0, but not everytime. What could be the cause of this? Sometimes the check engine light will come on but not always. Codes from this are unknown at this time.
Sep 10, 2020 at 5:58 AM (Merged)
we need the code
it is a fly by wire issue with either the throttle body failing or the pedal sensor has failed
VLDXGDVO
engine reduce power on 2005 silverado 4x4 6.0L
  • 110,248 POSTS
You need to have the computer scanned to identify what is causing this. Most parts stores will do it for free.
JENIMILLS
The truck will run fine for a few days then the reduced engine power will flash and I cannot go over twenty mph. I carry a small scanner to clear the code and will be fine for an hour, day, a few days etc. We have replaced the accelerator sensors, just put a new used engine in last week for other problems. The new spark plugs and wires, new gas pump, water pump. I got the truck back yesterday from the mechanic and had the issue this morning.
Good morning.
P1125
Item Description
Symptom/DTC P1125
Descriptor
Probable Causes
Accelerator Pedal Position (APP) Sensor
This sounds like the engine is going into limp mode due to a dirty throttle body here is a guide to help fix it.
and
https://www.2carpros.com/articles/reduced-power-limp-mode
JENIMILLS
You nailed it the throttle body has really bad, all cleaned up now runs great! thanks for the help.
Good to hear, please use 2CarPros anytime we are here to help.
SOPHIEGIRL
my truck is telling me to reduce engine power and then it only wants to go about 25 miles per hour if i turn it off and wait for about 15 minutes it will run fine for a little while
there is a problem with the fly by wire unit. it could be the throttle body unit that is bad or the pedal sensor that contains the TAC module. get a shop to check the unit with a scan tool to verify and give you a bid.
CADIEMAN
  • 3,544 POSTS
check the fuel pump pressure.watch for the pressure to drop off when it stalls.
LERINCK
I am wondering why every time the headlights come on the engine goes to limp mode and the dash reads reduced engine power and I get a obd code 1518? It only does it when headlights come on. Can run the parking lights and runs great all day with air conditioner, radio, and all on but as soon as the automatic headlights come on it does the reduced engine power thing. Replaced the tac module, gas pedal, and battery. Can the alternator be the cause or something else?
Sep 10, 2020 at 5:59 AM (Merged)
Good morning.
The 1518 revolves around voltage issues. I would double check the battery voltage when at rest. It should be 12.6. New battery or not, it needs to be checked.
Then you need to check the charging system. It needs to be 14 to 14.5 volts while running. also, check for any AC volts while running s well. There should be none.
It could be when the headlights are on, it creates a load and that voltage may be triggering the code.
CIRCUIT DESCRIPTION
The throttle actuator control (TAC) module and the powertrain control module (PCM) communicate via a dedicated serial data circuit. This serial data circuit is separate from any other serial data circuit on the vehicle. Accurate transmitting and receiving of serial data requires not only good circuit integrity but also adequate system voltage. This diagnostic test monitors the accuracy of the serial data transmitted between the TAC module and the PCM. If the PCM detects a loss of data or invalid data, this DTC sets.
CONDITIONS FOR RUNNING THE DTC
- The ignition switch is in the crank or run position.
- The ignition voltage is more than 5.23 volts.
CONDITIONS FOR SETTING THE DTC
- Invalid or missing serial data messages are detected for a predetermined amount of time.
- The above condition is met for more than 1 second.
ACTION TAKEN WHEN THE DTC SETS
- The PCM illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
- The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Freeze Frame and/or the Failure Records.
- The PCM commands the TAC system to operate in the Reduced Engine Power mode.
OR
- Under certain conditions the PCM commands the engine OFF.
- The message center displays Reduced Engine Power.
CONDITIONS FOR CLEARING THE MIL/DTC
- The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
- A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
- A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
- Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
- DTC P1518 sets if the battery voltage is low. If the customer's concern is slow cranking or no crank because battery voltage is low, ignore DTC P1518. Clear any DTCs from memory that may have set from the low battery voltage condition.
- DTC P1518 sets when there is a short to B+ on the TAC module ground circuit. Inspect the fuses for the circuits that are in the TAC module harness-i.e. cruise, brake. An inspection of the fuses may lead you to the circuit that is shorted to the TAC module ground circuit.
- DTC P1518 sets if the TAC module ignition feed circuit is shorted to a B+ supply circuit. The TAC module stays powered-up when the ignition switch is turned OFF. When the ignition switch is turned ON, the TAC module is powered-up before the PCM. DTC P1518 sets because no communication is detected by the TAC module from the PCM. Inspect related circuits for being shorted to a B+ supply circuit.
- Inspect the TAC module power and ground circuits and the TAC module/PCM serial data circuits for intermittent connections.
- Inspect the TAC module connectors for signs of water intrusion. If water intrusion occurs, multiple DTCs may set without any circuit or component conditions found during diagnostic testing.
- When the TAC module detects a problem within the TAC system, more than 1 TAC system related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing an individual condition may correct more than 1 DTC. Remember this if you review the stored information in Capture Info.
- For an intermittent condition, refer to Intermittent Conditions. See: Computers and Control Systems > Initial Insp
FLASHBANG63
Okay I have reduced engine power. if I clear the code and turn my headlights to manual mode it will run fine. if I use the A/C or use high beam flash to pass or turn on headlights manually it fails into rep. if I pull either of my headlamps from the holders it stalls.
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a bad ground to the headlights there is a ground splice pack usually up by the headlights.
RICK4040
Engine Mechanical problem
2003 Chevy Silverado V8 Four Wheel Drive Automatic 76.586 miles
Hi ,I get a Reduced Engine power warning and I cant do more than 30 mil.an hour until I shut the Truck off and wait a spell then it will go for a day or so and do it again.
Need Help
Thanks
Rick
  • 110,248 POSTS
When the light is on, you need to have the computer scanned to identify where the problem is coming from. Most parts stores will do it for free.
ROBERTBARNES62
  • 83 POSTS
While sitting in a drive thru a message come across the dash that said reduced engine power. It entered this mode and I have no idea as to what it be causing it. I was told it is more than likely the throttle body so I put a new one on and it still says reduced engine power. Any help on how to proceed would be great.
Not sure if it is related but I removed the negative battery cable so I could replace the fuel pump, when I reconnected the battery terminal there was a problem where the radio would not turn off when I opened the door after turning the truck off, also when the key was in the ignition and the door was open it would not chime. The solution for those problems was disconnect both battery terminals and reconnect. I tried just the negative terminal but it did not fix the problem, I had to disconnect both the positive and negative to get the radio and chime to start working properly.
  • 110,248 POSTS
Reduced engine power can be the result of a few different things. Engine temp, fuel issues, ignition issues, throttle actuator control system, and so on can all set that code. What you need to do is have the computer scanned for diagnostic trouble codes. That will point you in the direction of the problem.
I realize you replaced the throttle body, but the TAC involved more. Here is a list of components:
The TAC system components include the following:
- The accelerator pedal position (APP) sensors
- The throttle body assembly
- The throttle actuator control module
- The powertrain control module (PCM)
This is why it's important to scan the computer. In all honesty, all of the above items can be somewhat expensive, so we need to determine the root of the cause first.
Now, here is a quick video that shows how it's done.
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a auto parts store will scan it for free. Have that done. My only concern is this. If the reduced power indicator hasn't returned since the battery was disconnected, it may not show what we need. However, it should be done.
Let me know if this helps or if you have other questions. If you determine what codes are stored, let me know what they are and we'll work through it together.
ROBERTBARNES62
  • 83 POSTS
I am going to get it scanned tomorrow and will update with what is found.
  • 110,248 POSTS
That sounds like a plan. Honestly, I wouldn't want you to just replace parts that are good. Lets see if the codes show up and point us in the right directions.
ROBERTBARNES62
  • 83 POSTS
just pulled the codes and got the following:
P0120
P0220
P1515
P1516
P1518
P2135
I did clear the codes and they came back as soon as I cleared them.
As I state above I did put a new throttle body on the truck but that did not help any..
  • 110,248 POSTS
Those codes all are associated with the throttle actuator control module (TAC). Now, there are a list of checks for these codes, but to start, I suggest simply checking the wiring to the TAC module. It is under the hood. I attached a pic of it. I highlighted the connector and circled the module. I want you to unplug it to confirm there is no damage to the connector and no corrosion causing a bad connection.
Before you unplug the module or plug it back in, make sure the battery is disconnected.
Do this and let me know what you find. Also, let me know if you are comfortable following diagnostic flow charts.
ROBERTBARNES62
  • 83 POSTS
I have unplugged and inspected the wires and nothing seems to be broke or damaged. Please provide what I should do next. As far as flow charts never followed one but would open to try if it will allow me to get it fixed faster. Lol
ROBERTBARNES62
  • 83 POSTS
Got up this morning and started to check grounds and all connections to tax module, pedal and throttle body. Still getting the reduced engine power message. When I cleared the codes and re-scanned it now only brings up p0120 and p2135 codes.
ROBERTBARNES62
  • 83 POSTS
Also, my scanner says TPS is at 100%.
ROBERTBARNES62
  • 83 POSTS
so after saying a few bad words and then laughing at how i could not figure it out!!! i decided to put the old throttle body back on and now all codes have went away and the truck is not in reduced engine power anymore. I don't understand how it is now acting normal and driving fine? I know I had move wires around to test different pins on the throttle body as well as reached behind the passenger side to check the ground back there but i didn't take any wires loose or anything. I ran out of time today, had to come to work, but tomorrow I guess i need to start shaking wires to see if the code comes back on? any help would be appreciated.
  • 110,248 POSTS
That is both good and frustrating news simply because the lights are off now, but your uncertainty of the cause. I have to be honest, since it is working now, you moved something that caused a connection to improve.
I have to tell you that these vehicles have engine grounds which are known to corrode, break, and so on. So the idea that you moved the ground, I would start there. I have gone through vehicles like this that show continuity to ground as good, but as soon as a load is placed on the ground, it would fail. It's just a thought.
Let me know what you find or if you need any schematics or help.
ROBERTBARNES62
  • 83 POSTS
Where are the “main” grounds I need to check first? I think there is one or two behind the block and another one or two at the frame, but not sure. If you can send me the location of them I can at least clean them.
  • 110,248 POSTS
The throttle body is grounded through the ECM. After tracing through about 10 pages of schematics (LOL), the primary ground for the ECM is at the right front of the engine. See attached picture.
ROBERTBARNES62
  • 83 POSTS
What ground is behind the engine?
ROBERTBARNES62
  • 83 POSTS
I read that there is a GM service bulletin saying to check g103 and g104 when having TPS problems. can you tell me where those grounds are please?
  • 110,248 POSTS
Both are behind the engine. I attached a pic so you can locate them. I indicated which is 103 and 104.
Let me know if this helps.
ROBERTBARNES62
  • 83 POSTS
What uses these grounds?
CHUCK903
Driving down the road and it will go into limp mode or reduced engine power. Seems to happen more frequent in warmer temperatures. I have changed out throttle body three times, the throttle peddle, throttle sensor, battery, fuel pump, fuel filter, and crank position sensor. Now wondering if it is in the transmission or wiring.
Good morning.
Okay, were there any codes set or is the check engine light on? That will give us a clue of the area of failure.
https://www.2carpros.com/articles/engine-has-low-power-output
