Rear differential clunk when accelerating from a stop?
JBROWNENG
  • 15 POSTS
It was not in 4WD. I have not tried to duplicate the sound while in 4WD.
Thursday, October 12th, 2023 AT 10:26 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,247 POSTS
That's a good sign, did you have any metal inside the differential after you took the third member out?
Friday, October 13th, 2023 AT 8:15 AM
JBROWNENG
  • 15 POSTS
I do not know what you mean by "third member"?
There were no signs of damage and no metal shavings or pieces when I pulled the differential. There were no metal shavings on the magnet in the housing of any note and no fines in the bottom of the housing either.
I replaced the junk yard differential into my vehicle and had no change in the sound/vibration. I am now thinking it must be the transmission. I do not believe it would be the front differential as it is only engaged during 4WD isn't it?
Monday, October 16th, 2023 AT 9:14 AM
KEN L
  • 54,247 POSTS
Yep, I don't think it is the front differential either. It must be the transmission. I would try to service it first to see if you have any metal inside.
Please go over this guide and get back to us.
Monday, October 16th, 2023 AT 10:01 AM
