Rattle on slow acceleration
96,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
TBRISTLE
I have been having a rattle, best heard during slow acceleration up a hill. I had the transfer case fluid replaced and it sounded like it went away for a little while...now its back. Not sure if that was related...Any thoughts????
Jan 13, 2016 at 7:57 AM
CARADIODOC
  • 34,402 POSTS
What you described is more often caused by a loose exhaust system heat shield or rusted clamp. Bang on those areas with a rubber hammer while listening for the noise.
Jan 13, 2016 at 8:15 AM
TBRISTLE
will do...Thanks! I wonder why the sound went away after the transfer case fluid was replaced...
Jan 13, 2016 at 8:19 AM
CARADIODOC
  • 34,402 POSTS
That's very common. The exhaust system was most likely removed and other parts were shifted around. Shields often crumble from corrosion around the bolt holes. Even a little momentary pressure on one can make it stop rattling until vibration or more corrosion cause it to become loose again. Loose heat shields that were welded on each end to a pipe can be tightened with a hose clamp. Shields bolted to the underside of the floor can be tightened by removing the bolt or screw, then adding a large-diameter washer under its head.
Jan 13, 2016 at 8:24 AM
TBRISTLE
Thanks again! Have a great evening
Jan 13, 2016 at 8:27 AM
