Engine overheats on highway?
  • 110,176 POSTS
The radiator can do that; however, the oil wouldn't have gotten dirty as a result. Did they maybe find a creamy substance in the oil that would indicate a bad head gasket?
As far as the heat not working, if there wasn't enough coolant in the engine, it won't produce heat.
What I recommend is if you can, replace the radiator yourself. You should be able to get one for under 200 dollars. I feel 400 in labor is nuts.
Wednesday, October 28th, 2020 AT 2:06 PM (Merged)
ZACMAN44
Thanks. I checked back with them and the cost of just over $600 included the towing of $80 - though that is disputed as I was quoted $40 - and cost to check it all out (cooling system) and for new thermostat as well.
I will go ahead with it as car is at a shop now and about 50+ miles from where I live and not practical to put it in myself.
They mentioned some possible leakage by the water pump and given that I have 176,000 miles with no work yet on that I think I will have them replace that now to avoid problems.
Re the oil - he just said it looked dirty - but I have been told that before when it was clean -
Do I have to do anything now so that the donation reaches you?
  • 110,176 POSTS
You don't need to do anything. As far as the oil, wait until you can check it.
Wednesday, October 28th, 2020 AT 2:07 PM (Merged)
  • 110,176 POSTS
You don't need to do anything. As far as the oil, wait until you can check it. If there is coolant near the water pump, it most likely bad too if it is the original one.
KREZLAR
  • 2000 FORD RANGER
  • 3.0L
  • 6 CYL
  • RWD
  • 145,000 MILES
My truck is over heating and I do not know why. I have changed out the thermostat, I have ran it with out the thermostat, it has a water pump that was just put in this summer, I have bypass the heater core as well and it is still over heating. Where else should I look? I need my truck for work and it is causing issues any help would be appreciated
CARADIODOC
  • 34,368 POSTS
You need to provide some details or observations, otherwise there is no way to diagnose this over a computer. Bypassing the heater core will make any overheating worse. That's a small radiator that you just took out of the system.
What are the indications it's overheating? Do you see bubbling in the coolant reservoir? If so, does that occur within a couple of minutes of starting the cold engine or not until you've been at highway speed for a while? If there's bubbling in the reservoir, is there steam too? Does the upper radiator hose feel really hot? It should be too hot to hold onto for very long. Feel across the radiator for cold spots. Is the shroud around the radiator fan missing?
KREZLAR
Shroud is there, the top hose does get hot and hard. No bubble sin coolant. My truck will slowly warm up and then just keep right on going there is no maintaining. So I should hook the heater core back up but if it is broke could that cause my issue as well but even bypassed it overheats.
CARADIODOC
  • 34,368 POSTS
If the heater core is leaking, it can allow air to get into the system. If that air pools under the thermostat, (same as if a cylinder head gasket is leaking), it will prevent the thermostat from opening. Thermostats must be hit with hot liquid to open.
When the engine is hot, feel across the radiator to see if there are cold areas indicating some of the tubes are plugged. If the entire surface is hot all the way down to the bottom, the radiator isn't giving up its heat to the surrounding air. That is due to corroded and crumbling cooling fins. Also try pinching the heater hoses. The heater core poses some restriction to coolant flow. With it bypassed, coolant may be circulating too easily through those hoses and is not going through the radiator.
$MILEY143
  • 2000 FORD RANGER
  • 166,000 MILES
My truck is overheating and I do not know why?
  • 31,937 POSTS
Start with a cooling system pressure test for any external leaks, also test pressure cap, replace thermostat and get the radiator core cleaned, not a back flush. Start here and let me know if you have any improvement.
TAVERDEJA
  • 2000 FORD RANGER
  • 6 CYL
  • 4WD
2000 ford ranger keeps overheating. I replaced thermostat but that didn't solve the problem.
MMPRINCE4000
  • 8,548 POSTS
If heater is not producing hot air, you may have a waterpump problem.
Otherwise perform a compression test, then cooling system pressure test.
ANGDI38
  • 2000 FORD RANGER
  • V8
  • 73,000 MILES
Repair estimate to replace head gasket? Due to severe overheating was 1800 $. I do not have detailed list of replacement parts yet, can you advise what would normally be involved and the estimated total cost?
Angdi38
  • 110,176 POSTS
That sounds a little high, but I don't know where you live. Replacement will be around 100.00 in parts and the book calls for 7.7 hours labor.
ADAMHICE
  • 2000 FORD RANGER
  • 6 CYL
  • 66,000 MILES
I was driving my Ranger and while on the road, I noticed a significant drop on my Power gauge on the dash, and the Batter indicator light came on in the dash as well. After noticing this, I then realized that my power steering went out, or at least I believe it did because it became very hard to turn. While this whole problem was happening, my car began to overheat as well, the temperature gauge jumped almost to as high as it could go. Any ideas on what could be giving me problems? I just made it home in time.
Wednesday, October 28th, 2020 AT 2:08 PM (Merged)
ENGINEMAN 73
  • 28 POSTS
Sounds like you may have broken drive belt. Check that and reply.
ADAMHICE
You mean the serpentine belt? Cuz I just replaced that like a week ago.
ENGINEMAN 73
  • 28 POSTS
May have came off or broken.
TAVERDEJA
  • 2000 FORD RANGER
  • 6 CYL
  • 4WD
2000 ford ranger keeps overheating. There seems to be pressure building up. Overflow tank keeps filling up to the point of blowing cap off off tank.
WRENCHTECH
  • 20,761 POSTS
That's a pretty good indication of a blown head gasket, probably caused by a previous overheating. I would have it chemical tested to verify that.
