Random misfiring after replacing injector and removing others
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Friday, January 3rd, 2020 AT 3:04 PM (Merged)
TSMITH2000
  • 1996 DODGE AVENGER
  • 6 CYL
  • FWD
  • 151,000 MILES
I have a 96 dodge avenger has bad miss have replaced plugs wires dis cap rotor button fuel and air filter and intake gasket no service codes through computer?
1.Defective spark plugs
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
12.Mass Airflow Sensor
13.Idle air control valve
Note: If it doesn't apply disregard it-
