Ran without oil bad rod knock when starting
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICK LOMBARDI
vehicle was run without a drop of oil. It was running perfect, shut it off put oil in went to start it sounded like a bad rod knock and would not run. After sitting overnight started it up with a loud knocking which seemed to go away when I drove it home. sat for four hours started again, it idles rough a lifter tapping do not know if it will lesson if driven. Also, blowing some smoke. how much damage could have been done and is there a product to add to oil or radiator to fix any of this temporarily?
Dec 28, 2016 at 9:33 AM
CARADIODOC
  • 34,408 POSTS
Nope. She is due for a rebuild. The first clue is the rod knock. That means the engine bearings are chewed up. They are made of very soft metal. The pieces will flake off, then the harder layers will tear up the crankshaft journals. Those journals are very highly polished, and the clearance between them and the bearings is in the order of .006". That tight clearance is needed to maintain oil pressure.
The bearings and crankshaft must be replaced, and the engine must be removed to do that. Problem is the lack of oil pressure also prevented the oil from being sprayed onto the cylinder walls to lubricate the pistons. The cylinder walls might have survived serious damage, but do you want to take a chance on going through all that work for the crankshaft only to overlook all the other problems? Typically pistons and rings will be needed and the cylinders will need to be honed, and possibly bored to a standard oversize first.
Lifters can survive without oil. They will bleed down and rattle badly, but they will still work. The problem here is the lobes on the camshaft get oil only from what drains back after being pumped up to the lifters. The mating surfaces between the lobe and lifter are so highly-polished, and they wear in together so perfectly that when removed, we always reinstall each lifter back with its original lobe. Given how precise they are, those surfaces will be badly degraded too from lack of oil. Even with a new crankshaft and bearings, the camshaft lobes will continue to wear very quickly, then you will have more problems.
I rarely take my own advice, but this is one time you want to do it right. Do not try to do a quick fix.
Dec 28, 2016 at 11:29 AM
RICK LOMBARDI
It overheated during this mess and i think the smoke is from cracked head gasket. i have used bars head fixer before and it works. also, have researched other liquid fixers to buy me some time. do you think its worth trying them first? i just do not have the cash for a rebuild right now and i need my vehicle.
Dec 28, 2016 at 11:49 AM
JOHNNY G.JR
  • 320 POSTS
If it is blue smoke your engine is toast, it is just a matter of time before it seizes completely.
Dec 28, 2016 at 5:14 PM
CARADIODOC
  • 34,408 POSTS
Yup. You are putting new shoe laces on a pair shoes when it is the holes in the bottom that are letting water leak in. You are putting rocket fuel in a rocket that has already crashed. You are still typing on a Lenovo G50 laptop that has already been smashed and thrown against the wall out of frustration over the extremely miserable keyboard!!! Do you get my meaning?
If you think some mechanic-in-a-can is going to solve this problem even a little, be very sure you do not drive any further than you are willing to walk back home. Once this damage starts, parts continue to be destroyed at an ever-increasing rate. What you will end up with is fewer and fewer parts will be reusable to the point it does not pay to rebuild the engine. Right now it is a good bet connecting rod bearings are needed. Imagine a 3" long nail needs to be pounded into a board, but with the hammer on the nail's head, you only have 2" to swing that hammer. The nail is not going to move very far with each blow. That equates to that .006" clearance I mentioned earlier. If you tap on that nail all day, eventually it will sink in a half inch. Now you can swing the hammer 2 1/2". The bigger swing means you can drive the nail in further with each blow. The more pounding you do, the more the nail moves with each blow. The more pounding takes place between the connecting rod and the crankshaft journal, the more wear takes place with each blow. Within two or three miles, the connecting rods will be distorted beyond the point where they can be machined and reused.
The soft aluminum pistons are already scuffed, and metal chunks have collected in the piston ring grooves. No chemical is going to fix that. Their rough surfaces will gouge the cylinder walls, so the cylinders will need to be bored to a standard oversize. The valve stems have already been run dry, so there will be excessive clearance between the stems and guides. The camshaft lobes will be scuffed and will deteriorate rapidly. Adding oil now won't stop that wear from continuing and accelerating.
If you are going to do anything, dump in the highest viscosity oil you can find, then see how far you can get. Instead of a rebuild, it would make more sense to find a good used engine from a salvage yard. Chrysler has built a lot of really tough engines over the years, but even they need oil.
Another solution you might consider is renting a car, then looking for a community college with an "Automotive" program. In my school, we were always looking for live work to give our students real-world experience. We charged $10.00 per hour for what the job was supposed to take, and we got parts at real good discounts, then marked them up ten percent to form a "breakage" fund in case we damaged something.
The trade-off for the low repair cost is it will take weeks to get your car back because the students are only in the shop for a few hours per day. Also, we only taught "Engine Repair" once a year, for eight weeks. Your repair must fit what we are currently teaching. We would not do a brake job, for example, when we were teaching "Automatic Transmissions". To do so would take work away from the shop owners who hire our graduates.
Our students were very responsible and well-supervised, but they do not have the experience of older mechanics. Simply replacing an engine might not provide much of a learning experience compared to rebuilding it, but if they are hard up for appropriate jobs, this might be a solution worth looking into.
Dec 29, 2016 at 5:32 AM
