radio
196,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
RICKY ROWLAND
  • 11 POSTS
Crank this car up all radio station are gone, but if you just turn on the switch with out cranking the car all the stations will be there and radio will play all station fine, but soon as you crank the car all program stations will be gone. this issue has about drove me crazy. please help. Thanks
Jun 28, 2017 at 6:46 AM
STEVE W.
  • 15,409 POSTS
Check all of the fuses for the radio. It sounds like the KAM power feed is shutting off when you turn the key.
Fuses are radio 1 (under hood fuse box) and radio 2 (left side of dash fuse panel)
If both fuses are okay then you likely have a bad radio.
Jun 28, 2017 at 11:24 AM
