Radio will not stayed programmed
RICKY ROWLAND
  • 1999 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • FWD
  • 194,000 MILES
When I program the radio station they stay programmed as long as the car is on once I turn the car off the stations goes away. When I turn the car back on the stations are no longer programmed and the radio is always turned off ( even though it was on when I turned the car off).
Monday, February 6th, 2017 AT 4:40 PM
CJ MEDEVAC
  • 11,005 POSTS
Check radio 1 Fuse (20 amp).
Engine room J/B 2 (Left side of engine compartment).
This fuse should be hot/ powered at all times
The Medic
Monday, February 6th, 2017 AT 4:56 PM
