Radiator replacement
212,000 MILES
JESSNZACH10
  • 6 POSTS
i hace a 04 ford focus zts 2.3l and i am replacing the radiator but the new radiator i bought from advanced auto parts is only one peice as where the one i took out was two im just wonderinig if the new one will still work?
May 27, 2013 at 4:59 AM
no, take it back and get the correct radiator. the mounts are different
May 27, 2013 at 8:45 AM
JESSNZACH10
  • 6 POSTS
i believe the part i was talking about is my air conditioner conderser and my buddy cut the lines on it not knowing what he was doing taking out my radiator... do i need to re hook this up in order for the new radiator to work and is the other small radiator looking thing for the powersteering and brake fluid cooling?
May 27, 2013 at 9:09 AM
no, you can use the the radiator without the ac condenser.
May 27, 2013 at 9:34 AM
JESSNZACH10
  • 6 POSTS
is there a way to replace the lines with out replacing the aluminum tubes the lines run into on the condenser?
May 27, 2013 at 9:46 AM
where did he cut them and why???
roy
May 27, 2013 at 9:47 AM
JESSNZACH10
  • 6 POSTS
directly out of the condeser in between the two aluminum hard lines and thought they had to be cut to remove the radiator
May 27, 2013 at 10:42 AM
does not sound like much of a repair shop. you will have to replace both lines.
May 27, 2013 at 11:22 AM
