2003 Ford Focus How do i drain the coolant
SONDRA0911
Engine Cooling problem
2003 Ford Focus 4 cyl Two Wheel Drive Automatic
When fluishing the system(anitfreeze) how do i drain it i can not find a way to do it?
Oct 30, 2008 at 2:54 AM
  • 110,248 POSTS
Hi:
Normally the drain is at the bottom of the radiator. It looks like a wingnut. If you can't find it, it may not have one. To drain the coolant in that case, you need to remove the lower radiator hose.
Nov 20, 2008 at 5:45 AM
