2003 Ford Focus radiator
AMOS
  • 2003 FORD FOCUS
Engine Cooling problem
2003 Ford Focus 4 cyl Front Wheel Drive Automatic
Where is the drain plug? Thanks
Monday, November 10th, 2008 AT 8:55 AM
  • 109,885 POSTS
Hi:
The drain plug should be located on the bottom of the radiator. It will look like a wingnut. If you can't locate it or it doesn't have one, you will need to remove the lower hose to drain the coolant.
Thursday, November 20th, 2008 AT 1:36 PM
