Radiator fluid leaking
2001 GMC JIMMY
112,347 MILES
FRILL
What can be the problem that would make the radiator fluid leak?
Mar 31, 2017 at 11:10 AM
HMAC300
  • 48,601 POSTS
if it is leaking fill the system up then get a pressure checker and pressurize the system to see where it is leaking. auto parts have them and rent them out. if it looks like leaking on crank pulley it is probably a water pump. if no leaks are seen then it may be an internal leak like a head gasket.
Mar 31, 2017 at 12:13 PM
