1995 GMC Jimmy Antifreeze Leak
DRAGON23S
I have a 1995 GMC Jimmy, it is the down-szie version.
4.3 L engine and 4WD.
I was driving down the highway when the check gauges light came on. I noticed that the temperature gauge was very high, even in the red sometimes. I tried turning on the heater to cool the engine, but there was very little heat coming out. When I got home I opened the hood looking for a leak. There was no coolant in the overflow tank and no hoses leaking. I looking underneath the car and the bottom of my car had antifreeze on it. Most of it was on the front differential for the 4WD, but there were parts of the frame with antifreeze too. I have not checked the radiator level yet because the engine is still hot.
I'm thinking that it may be the water pump, but I can see if there is any coolant leaking from this.
I am going to make an appointment with my mechanic, but I was hoping to get your opinion first
Nov 10, 2007 at 12:00 PM
CHEVY22
  • 1,375 POSTS
hi,
there are a few things it could be; one would be the water pump as you stated. two the lower intake leaking down the front of the engine or three the radiator , a cooling system pressure test should reveal the exit point of the leak. good luck
Here is a guide to help: https://www.2carpros.com/articles/car-is-leaking-coolant
Jim
Nov 10, 2007 at 1:16 PM
Suggested Repair
Have the cooling system pressure-tested to find the leak. Likely sources are the water pump, a lower intake manifold leak running down the front of the engine, or the radiator.
Conversation Summary
The owner of a 1995 GMC Jimmy reported highway overheating, little heater output, an empty overflow tank, and antifreeze on the underside near the front differential and frame. The expert said the leak could be the water pump, lower intake, or radiator and recommended a cooling system pressure test to locate it.
