Water is leaking out of the side of the radiator
140,000 MILES • 4WD • AUTOMATIC
DANA.GAS2002
I’m broke down and trying to get it home with no money. Is there a home remedy of something I can put in the radiator to seal it to get it home? I heard pepper. I heard put three eggs. Just wanted to know for sure.
May 7, 2021 at 6:44 PM
  • 110,248 POSTS
How badly is it leaking? Often times when it is one of the tanks on the side, they are nonrepairable. The ideas you mentioned above I have heard of, but in all honesty, I never tried them. If it is a bad leak, I can't see how they would work.
If it isn't a bad leak and you have a short distance, you can try leaving the radiator cap on the first click so pressure doesn't build. If nothing else, that will slow things down.
May 8, 2021 at 2:03 PM
