SadUCFKnight.
Ford Explorer Can A Radiator Leak Destroy A New Transmission
SadUCFKnight.
Pud, could you tell me briefly how this is possible? Also, how frequently does problem happen? Thanks for the help....
good luck
Darryl...
Suggested Repair
Check the radiator and its internal transmission cooler for a leak. Coolant in the transmission, or transmission fluid in the coolant, indicates the cooler failed and contaminated the transmission. Replace the leaking radiator/cooler and repair or replace the damaged transmission so the failure is not repeated.
Conversation Summary
The owner of a 1996 Ford Explorer asked whether a failed radiator could destroy a transmission installed four months earlier after a mechanic denied warranty coverage, saying the radiator flooded the transmission. Experts confirmed this can happen. One explained that loss of transmission cooling overheats and ruins the fluid and transmission. Another explained that many transmission coolers are inside the radiator, so a leak can send coolant into the transmission and transmission fluid into the coolant, destroying the transmission. Transmission fluid in the coolant was identified as a clear sign of an internal cooler leak.
