1998 Ford Explorer Invisible Water Leak
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
COACHMAC59
I have a water lead somewhere that I can't find.
I fill the radiator and the next day it is low.
The reservoir is still full. I can not see any visible
leaks. Help
Jun 11, 2009 at 2:07 AM
DOCFIXIT
  • 18,828 POSTS
White smoke from exhaust? Rough run on A.M. start up? Check oil look normal? Any recent overheating?
Jun 11, 2009 at 2:19 AM
COACHMAC59
No white smoke, no water in oil, no overheating.
Jun 11, 2009 at 2:29 AM
DOCFIXIT
  • 18,828 POSTS
Suggest you have cooling system pressure tested to find leak.
Jun 11, 2009 at 4:12 AM
