Car stopped moving after drive only a few minutes
185,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
GODSSONIBK
My car did not overheat, but my car stop moving after driving for a few minutes and will not accelerate when the gear is engaged. we found out coolant and the gear oil have mixed together, but i am not sure if it is gear oil or the engine oil is what mixed with the coolant. car did not overheat and the engine is running but stop moving after a few minutes when the gear is engaged.
Feb 11, 2018 at 7:48 AM
Good evening.
What color is the fluid?
Feb 11, 2018 at 9:23 AM
GODSSONIBK
The fluid in the radiator was milky color and the transmission fluid also milky color like a strawberry.
Feb 11, 2018 at 9:44 AM
that indicates transmission fluid which comes from a leaking cooler inside the transmission. you will need to replace the radiator, completely flush the cooling system. you will also need to flush the transmission out as well. once that is done, keep an eye on the transmission. coolant in the transmission is not good and can cause the transmission to fail.
Feb 11, 2018 at 9:40 PM
