Quarter Glass Power Window Will Not Raise On Convertible
2008 FORD MUSTANG
101,000 MILES • 4.0L • V6 • RWD • AUTOMATIC
MANUELPTK210
My rear driver-side quarter window had been making a grinding noise, sort of like a twig breaking apart, for months. I figured that a twig somehow made its way behind the rubber body seal near that window and ignored it. Well, two days ago I put the top down on the vehicle, along with the windows, and they all came back up except for the one that was making the noise. When I try to engage the power window option, all I get is that grinding noise but no movement whatsoever.
I'd like to avoid a repair at this time, if possible. Is there a way that I can manually lift the window to seal it? I tried pulling the window up already, but it seems to be secured in the down position. If this is better left to a mechanic, what should I expect in terms of cost for the repair?
Oct 29, 2014 at 1:18 AM
  • 110,244 POSTS
It sounds like one of the gears has stripped. You need access the motor, loosen it enough so the gears no longer touch. Then you could move the glass.
I have to be honest, I would recommend having it done by a shop. I wouldn't expect it to be more than 75.00, but I'm not sure where you live.
Oct 29, 2014 at 1:36 AM
MANUELPTK210
Thank you for your reply. I will call around to price the work.
Oct 29, 2014 at 1:42 AM
