I dont have a diagram, just thiese instructions.
DOOR TRIM PANEL Removal & Installation 1. Using flat-blade tool, pull door trim panel accessory trim plate away from door trim panel at service notch. Lift door trim panel accessory trim plate away from door trim panel to release retaining clip at rear. Remove door trim panel accessory trim plate. Using a small flat-blade screwdriver, disconnect switch harness connector(s). Set door trim panel accessory trim plate aside. 2. Remove inside door handle pull cup. Remove trim cover, inboard from exterior mirror near "A" pillar. On models with premium sound system, remove door speaker. On all models, remove door trim panel -to-door retaining screws. Release door trim panel -to-door pin-type retainers. Lift upward on door trim panel. Remove door trim panel. To install, reverse removal procedure. All parts store carry the tool..
Jul 13, 2009 at 1:01 AM
