Problem cold starting
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRYANTHERRIEN2015
When trying to start, the van will start, then shut off, unless you tap the accelerator while starting. Sometimes the starter will actually hang up and continue turning over after the van is already running. I have tried to clean the mass airflow sensor, but am not sure how to remove it from the housing. Any help or suggestions will be greatly appreciated.
May 12, 2019 at 3:20 PM
  • 55,740 POSTS
It sounds like the throttle body needs to be cleaned, disconnect the battery before you begin. here are two guides to help us fix the problem:
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
May 14, 2019 at 4:14 AM
