Power loss and backfires?
180,000 MILES • 4.0L • V6 • 2WD • MANUAL
STEVEHIX
I replaced cats with strait pipe but included flanges with o2 sensors. I changed plugs air and fuel filters, plug wires, cam position sensor, EGR solenoid, cleaned throttle body, MAF sensor, cleaned injectors, replaced one of the temperature sensors, and cleaned all connectors and greased them. I got the vehicle to idle and drive but it has no power and backfires it actually runs better if I pull the PCV.
Nov 16, 2023 at 1:52 AM
  • 110,248 POSTS
Is the check engine light staying on? If so, have you checked for diagnostic trouble codes?
Keep in mind, the oxygen sensors' signals are going to be off because there will be no change between the upstream and downstream sensors. The catalytic converter makes the difference. This will result in the air/fuel mixture causing issues.
Do you have a live data scan tool? If you do, check the short-term fuel trims and let me know what they are. Do this when the engine is at operating temperature.
Next, watch how the oxygen sensors' voltages are changing. They should be between 0.1 and 1.0v.
Nov 16, 2023 at 1:12 PM
