Power loss
51,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
LOUISED85
My car loses power momentarily on accelerating. It shudders a bit?
Apr 27, 2016 at 4:17 AM
HMAC300
  • 48,601 POSTS
scan for codes and check the fuel pressure with a gauge auto parts rent it.
Apr 27, 2016 at 5:00 AM
LOUISED85
Okay. If read it, could be timing chain or camshaft position sensor to? Hopefully not a big job as just bought the car
Apr 27, 2016 at 5:06 AM
  • 55,604 POSTS
Hi LOUISED85,
If the check engine light is not on then it could be the crankshaft angle sensor which has a history of failure on these cars. The tough part is when this sensor fails it may or may not set a code. Here is a guide on what to expect when changing the sensor
The engine is different but the procedure is the same,
The location of your sensor is the right side of the engine block look for a three wire connector
Please let me know what you find.
Best, Ken
Apr 27, 2016 at 9:57 AM
