Possibly warped rotors and brake pads?
60,000 MILES • 2WD • AUTOMATIC
MAKINZIEG97
Whenever I step on my brakes while going downhill at speeds higher than 50 MPH my steering wheel starts shaking and when I’m stopping my car the car begins to pulsate while I step on the brakes. Any possible idea what this is? I can get my vehicle diagnosed but I’d rather save that money towards the cost it’s going to be to fix it in the near future.
Jul 5, 2023 at 4:05 PM
JAY-DOUG
  • 7 POSTS
Does this issue only happen when braking downhill? What it sounds like to me is your brake rotors/discs are “warped”. This can happen due to old age which then the rotors will become thinner and thinner and eventually warp or excessive/hard braking which will then cause them to become very hot and warp. When you’re replacing your rotors you will want to also replace the brake pads as those will have uneven wear from bad rotors. I’ve had vehicle do this before and replaced the rotors and pads and had no more pulsating in the steering wheel. Let me know if that solves your issue. Thanks
Jul 5, 2023 at 5:56 PM
  • 110,251 POSTS
What you described does sound like the brake rotors. Since you feel it most in the steering, it is likely the front brakes.
As far as the rotors are concerned, the brake pads should be replaced at the same time. Additionally, make sure the slid pins are free and there is no rust built up on the caliper mount where the brake pads sit.
Here is a link that explains in general how it's done:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Let me know if this helps or if you have questions.
Jul 6, 2023 at 3:21 PM
