2001 Kia Optima No Brakes
2001 KIA OPTIMA
60,000 MILES • 6 CYL • FWD • AUTOMATIC
RJMARS1
I replaced the calipur on the rear passenger side of the vehicle. While I was bleeding the first one(the one that i replaced) my friend pumped the brakes while the bleeder was open. I didnt think anything of it at the time but after i took it for a test ride i had no brakes. The pedal went right to the floor. The car did stop but it took quite a distance. So i went around and bled all the brakes and only really got air out of the other back brake. It did not help. Im pretty the resivor went epmty after the brakes got pumped with the bleeder open. Can you tell me what happened and or what i need to do now to get my brakes back?
Thank You for You're Help,
Randy
Mar 11, 2008 at 11:48 AM
MASTERTECHTIM
  • 4,750 POSTS
if in fact you let the master cylinder go dry then you will have to keep bleeding brakes until you get all the air out from all 4 wheels. remember the air has to travel from master to each wheel so you really have to bleed the mess out of it.
Mar 11, 2008 at 11:59 AM
RJMARS1
Will I need a special tool to get the air out of the abs system?
Mar 12, 2008 at 6:18 AM
MASTERTECHTIM
  • 4,750 POSTS
NO special tools needed
Mar 12, 2008 at 7:21 AM
