Porsche A/C Blower High Amps
PORSCHE
SSMJG2K
I need to know what amperage should this blower be at? My reading is 14.2 amps on a 30 amps fuse and the wire is getting hot. :(
Your answer is appriciated, Thanks Sal
Jul 5, 2006 at 8:40 AM
  • 55,837 POSTS
If the wire is getting hot it is pulling to much amperage. 14 amps at start up is ok, but then it should drop to about 7-9 amps. Try replacing the blower motor.
Sep 12, 2006 at 11:37 AM
Suggested Repair
Replace the A/C blower motor. About 14 amps at startup can be normal, but current should then drop to about 7-9 amps. A wire that stays hot indicates the motor is drawing too much current.
Conversation Summary
The owner of a Porsche asked what amperage the A/C blower should draw after measuring 14.2 amps on a 30-amp fuse and finding the wire getting hot. The expert said about 14 amps at startup is acceptable, but current should then fall to about 7-9 amps. A hot wire means excessive draw, so the blower motor should be replaced.
