1985 Porsche 944 Starter Spins
You will have to remove the top belt cover and check if the cam is turning when cranking. That the easy bit. If the cam belt has failed (these should be replaced every 80,000 Kms not to sure what that is in miles) Engine damage will normally occure. There are two belts on this engine Cam & ballance shafts. This is a not a job for a backyard mechanic There are special tools and tension gauges required I do advise not to try this one yourself unless you can get the equipment you need.
Mark (mhpautos)
Suggested Repair
Remove the top timing belt cover and confirm the camshaft turns while cranking. If the belt has failed, engine damage is likely. Cam and balance-shaft belt replacement requires special tools and tension gauges and is not recommended as a DIY job without that equipment.
Conversation Summary
The owner of a 1985 Porsche 944 says the engine stalled after shifting and the starter now spins without engaging, even with a new starter and intact-looking ring gear. They ask whether a broken timing belt could cause this, if the engine is damaged, and whether belt replacement is a DIY job. The expert advises removing the top cover to see if the cam turns while cranking, notes that a failed belt usually causes engine damage, and says the cam and balance-shaft belts require special tools and tension gauges.
