1987 Porsche 944 Slips Then Kicks In
1987 PORSCHE
SABI'S 944
HI MY PORSCHE 944 1987 AUTOMATIC ITS GOING CRAZY WHEN I STEP ON THE GAS IT SPEEDS UP I CAN HERE IT BUT I DONT FEEL THE CAR SPEEDING UP AND THEN IT KICKS IN WHAT COULD BE THE PROBLEM PLEASE HELP
THANK YOU!
Mar 5, 2007 at 4:48 AM
  • 31,937 POSTS
Hi there,
Check that the kick down cable is not broken or over tight, the cable is the same as the throttle cable, they often brake at the throttle butterfly this will cause engine response but shift problems, also check trans oil level, (there is a level indicator on the rear of the transmission, this must be done with the trans warm & with the engine idling in park. low oil level will cause flairing ( this sounds like whats happening to you) finaly Have the transmission pressure tested there may be an internal mechanical fault.
Mark (mhpautos)
Mar 13, 2007 at 9:41 AM
Suggested Repair
Check the kickdown/throttle cable for breakage or excessive tightness, especially at the throttle butterfly. Check the transmission fluid level with the transmission warm and the engine idling in Park. Have transmission line pressure tested for a possible internal mechanical fault.
Conversation Summary
The owner of a 1987 Porsche 944 automatic says the engine revs when the accelerator is pressed but the car does not speed up until it suddenly kicks in. The expert says this can be caused by a broken or overly tight kickdown cable, low transmission fluid causing flare, or an internal transmission fault that should be checked with a pressure test.
