1976 Porsche 911 LOOSE AIR FILTER HOUSING
1976 PORSCHE 911
115,000 MILES • 6 CYL • 2WD • MANUAL
HOWARD GREEN
My Targa was difficult to start and then backfired a numbrer of times. On removing the air filter cover I found a vertical machine screw appears to be stripped and the whole filter housing is loose. The housing appears to be cracked at a seam on the left hand side. Does the machine screw secure the whole housing or does the housing need to be replaced?
May 6, 2010 at 7:06 PM
CWPORSCHE
  • EXPERT
  • 58 POSTS
You will have to replace the intake housing but there is a aftermarket kit you install to keep this from happening again. Its a spring loaded flap that allows air to escape when the engine backfires due to a lean condition usually.
Jun 27, 2010 at 5:42 AM
