1976 Porsche 911 Air cleaner housing
HOWARD GREEN
Engine Performance problem
1976 Porsche 911 6 cyl Two Wheel Drive Manual
The air cleaner housing is loose and I notice a crack or perhaps a seam on the left side. In the housing itslelf there is a vertical machine screw that appears to have stripped threads. Does this screw hold the whole housing down or do I have to replace the whole housing?
May 3, 2010 at 6:40 PM
MECHTRIX
  • 577 POSTS
if it has a crack in it '' replace it and use new hold down screws they usually crack because of repeated pressure burst that take place inside the housing caused by a eng out of tune it can be helped by adding a pop off valve ....best of luck to you....mechtrix
Apr 30, 2011 at 7:35 PM
