Poor acceleration at any speed
90,000 MILES • 4.5L • 4 CYL • 2WD • AUTOMATIC
MCKINNONJG
The car has very poor acceleration at any speed even with the accelerator almost to the floor.
somewhat better acceleration upon downshift. the car is able to achieve highway speeds up to 80 mph and does reasonable well on hills upon downshifting. There are no indicator lights nor messages such as reduced power.
The Camshaft Position Actuator was previously replaced do to the car riding like a bucking horse at low speeds and a P0010 - "A" Camshaft Position Actuator Circuit (Bank 1) code.
My question is: could the low power be caused by the Camshaft Position Actuator not working at all or because of some other part such as the throttle valve?
If the wiring is faulty would there be a engine code?
Aug 13, 2018 at 6:30 AM
Good afternoon.
From your description, I would suggest two things.
Check the fuel pressure. If you have low pressure it could cause this issue.
If you have a clogged cat converter it will also cause this issue. You need to do a back pressure test on the converter to confirm.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Aug 13, 2018 at 6:43 AM
STEVE W.
  • 15,423 POSTS
Welcome to 2CarPros.
Probably the first item I would check would be for a restricted exhaust. It is possible that the camshaft actuator was dumping extra fuel into the system and it clogged the converter. To check it requires a simple pressure gauge and removing the first O2 sensor. You put the pressure gauge in and read the back pressure. Anything over around 1-2 psi and you have a problem.
Aug 13, 2018 at 6:46 AM
MCKINNONJG
The exhaust also has a noticeable puff on my hand about 10-30 times per second at idle of 700 RPM.
Aug 14, 2018 at 8:37 AM
You need to do the tests I suggested. That really tells us nothing.
The tests are a starting point to find the actual issue.
Aug 14, 2018 at 8:54 AM
STEVE W.
  • 15,423 POSTS
At idle the exhaust could be passing enough to stay running, As soon as you step on the gas the exhaust flow can increase to the point it cannot flow properly. That is what the testing is for, to determine where the issue is.
Aug 14, 2018 at 10:23 AM
